Front Indicator Connector???
Black_Op_88
Post Fri Jan 18, 2013 4:05 pm
I need to reconnect mine its as simple as that, or maybe not I have read that I need to remove or loosen the front bumper. The car is an 89 325is Tech 2. I just need enough room to push the little blighter on. By the way its on the near side of the car if that makes any difference. Any help would be great.
Post Fri Jan 18, 2013 4:27 pm
bumper must be partially removed at least to get to it, there's no other way
Black_Op_88
Post Fri Jan 18, 2013 4:30 pm
And its the big Allen key bolts you remove isn't that right?
Post Fri Jan 18, 2013 4:33 pm
it is, they are Torx bits actually, T55 If i remember !
Topblag
Post Fri Jan 18, 2013 4:39 pm
Unless it's been removed recently, suggest a major spraying of WD40 at least 24 hrs in advance. Use a 1/2" drive socket, those bolts have broken three lifetime guarantee 3/8 drive T55 sockets with me.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
