Electric fan
Nato_e30
Sun Jan 13, 2013 12:15 am
Has anyone wired up a leccy fan? Im buying a 16" fan, I was going to hook it up on a switch .. but has anyone wired one up to some sort of fan switch... maybe with a manual switch in the cabin aswell...?
Im useless with wireing ect so would appreciate any help in direction... parts.. ect I need.
Many thanks g
steve_k
Sun Jan 13, 2013 12:21 am
I've got a diagram from willnz for wiring up a manual fan switch.
i'll PM it to you tomorrow.
should be of some help.
Nato_e30
Sun Jan 13, 2013 12:33 am
That would be fantastic steve, many thanks g
steve_k
Sun Jan 13, 2013 8:49 am
no worries dude, pm sent.
**BANNED**
Sun Jan 13, 2013 9:46 am
Some radiators come with a mounting boss on the o/s top as seen here;
This is intended for a thermostatic switch to drive an electric fan,radiators with this fitting can be found on cars with air-con.
Youth is wasted on the young.
Nato_e30
Sun Jan 13, 2013 6:51 pm
Cheers steve some bed time reading their, il take a look see if mine has the plug hole, cheers daimler :)
IlovM42
Tue Jan 15, 2013 3:29 pm
just wired mine on my 318is e30 trough the original fusebox last week :D
Bullet_Ride
Tue Jan 15, 2013 4:32 pm
I just cut the connector off my auxiliary fan and attached it to my after market fan, that way your fan plugs into the stock wiring harness and kicks on with the temperature switch in the rad. Since I removed my a/c if I want to manually turn on the fan I just press the a/c button because that automatically kicks on the aux fan.
MartyP1977
Sun May 12, 2013 11:39 pm
IlovM42 wrote:just wired mine on my 318is e30 trough the original fusebox last week :D
I have purchased an electric fan from an E36 (direct fit in place of the old fan shroud) and I also got the thermostat switch from its radiator. My E30 318is has the hole in the radiator with a blanking plug in it. As my car didn't have air con, could you give me some info on how to wire it up please?
