Replacing Fuel Lines?
Shiz
Very basc, but the fuel lines on my e30 look to be long past there sale by date. There all bascially rusted and will need replaced. Is their any descriptive write ups on here, or has anyone came across a thread with Pictures
. Instead of replacing them with metal fuel lines, would plastic/rubber lines the correct diameter of pipe etc be a better job so that they dont rust again. Thanks in advance folks.
cherryredbenj11
Im doing mine too, would like to know aswell
Jim320i
- E30 Zone News / COTM Team
Get them directly from the dealers... Not that expensive. I think Capri-Rob bought some not long ago at a good price from them.
To switch them its just cross head screws holding the brackets in place along the passenger side from memory... Simple enough job when you actually look at them
They were about £20 per pipe for the pre-shaped ones from BMW but that was a couple of years ago.
As for replacing with plastic can't really comment - I just coated them in waxoyl after fitting - should last the life of the car now
jonesy318
ive just put some on mine, cost something like £22 each, and all new clips about £10 for the lot. easy to fit and if the originals have lasted 20 odd years i dont think these would be any different
Idol
Can you get brake lines from the stealer??
maxfield
Yes.Idol wrote:Can you get brake lines from the stealer??
But they arent pre shaped - you need to bend them to fit.maxfield wrote:Yes.Idol wrote:Can you get brake lines from the stealer??
Shiz
how hard is it to bend them into shape?..thats.the hardest part i presume bending the pipes?
capnmchl
Are the dealer brake lines copper or steel then?
you can do it by hand if you're very careful but if you want it to look factory you need a proper pipe bending tool and to be very careful getting the old ones off so you can use it as a template to bend the new one into shapeShiz wrote:how hard is it to bend them into shape?..thats.the hardest part i presume bending the pipes?
Steel I think and they are coated/painted black, the correct length and with the fittings already in place.capnmchl wrote:Are the dealer brake lines copper or steel then?
Again a thick coating of waxoyl on fitting and regular re-treatments will mean they last a long time.
