horn not working?
cherryredbenj11
My horn isnt working on my tourer, horn is there fuse is ok, any suggestions?
sweep
was it a 6 cylinder originaly?
Rtaylor2208
Have you changed the steering wheel recently? There is a sprin loaded carbon brush behind the steering wheel which connects with the brass ring on the back of the wheel.
If you have changed the wheel they may not be contacting just when you press the horn the circuit is not complete to make it work.
cherryredbenj11
Havnet changed the wheel no, not since ive owned the car, couldve been changed before
Rtaylor2208
So has the horn ever worked?
First thing to do is turn the ignition on and listen to relay K2 in the fusebox to hear if it clicks when someone presses the horn push.
Next thing to do is pull out said relay, and use a short piece of wire to link together pins 30 and 87 of its base. Horn should sound.
