Removing the ews out of my donor car tonight. Just need to know are e34 linked to the speedo clocks because I'm sure the last time I looked there was a wire going into the clocks from the small module on the steering column. Also does anybody know where the main module is?
Been searching the net about it and not found much about removing the ews system to reuse it.
Any help appreciated cheers simon
Bmw e34 540i ews
Andyboy
- Alpina Colada
What year is the car? Got the last 7 digits of the VIN?
punk_sy
It's a 1996 on a n reg I can get the chassis number tonight if needed. Cheers
Andyboy
- Alpina Colada
No need, it 'll be EWS11 at that age, not the pre 1/95 EWS1.punk_sy wrote:It's a 1996 on a n reg I can get the chassis number tonight if needed. Cheers
All the E34's ive had the EWS module has been behind drivers side of the dash, behind the small compartment on the right
punk_sy
Can I just use a non ews ecu or will I need to get a non ews engine loom? Thanks for the replies didn't get chance to look at it last night tho. Didn't won't to freeze my bollocks off.
punk_sy
think i have everything here except the ecu still on the engine?
Uploaded with ImageShack.us
bit of a rubbish picture
Yep, its all there
punk_sy
Sound do you have a diagram for the wiring at all
. Carnt seem to find one. if not ill have another search. cheers
