what's the easiest way to diagnose faulty alternater.
e30geezer
Post Mon Nov 28, 2005 8:41 pm
hi, guys driving down the a13 tonight , the dash lights went dim , stereo went off, abs light came on , never done this before, obc went dim , headlights went dim, automatic gearbox light and window switches went off, but previously to this the battery kept going dead , put brand new 1 on , it last 2 days the dead again , it's so bloody annoying, do you think i have a bad earth? please help!!!!!!!
koos
Post Mon Nov 28, 2005 9:11 pm
Check the charge rate and the belts, see if it's charging probably. Check the earths like you say, and pos cables aswell.
e30geezer
Post Mon Nov 28, 2005 9:14 pm
koos wrote:Check the charge rate and the belts, see if it's charging probably. Check the earths like you say, and pos cables aswell.
mate, thanks gonna look at it tommorrow, hope this cures it. i know it's something stupid. let's see. cheers mate.
m-dtech
Unapproved Trader caution
Post Mon Nov 28, 2005 9:18 pm
typical of altenator failure.
e30geezer
Post Mon Nov 28, 2005 9:21 pm
m-dtech wrote:typical of altenator failure.
really, i hope not, but if it is it makes sense.
Post Mon Nov 28, 2005 11:32 pm
Dud altenator. Regulator/brush pack is available seperately.
This belongs in tech. help, so moving it.
PLEASE POST IN THE CORRECT FORUM.
Sarfraz
Post Mon Nov 28, 2005 11:36 pm
my one does that 2 itz da alternator thats gone !
e30geezer
Post Tue Nov 29, 2005 6:50 pm
Brianmoooore wrote:Dud altenator. Regulator/brush pack is available seperately.
thanks mate, sorry, whats the best way to test it.
e30geezer
Post Tue Nov 29, 2005 6:51 pm
Sarfraz wrote:my one does that 2 itz da alternator thats gone !
how much did it cost to put right mate?
Post Tue Nov 29, 2005 9:56 pm
Think you've already tested it when your new battery went flat in two days!
Only cable connections that could be at fault are the ones at the ends of the thick red wire that goes from the altenator to the starter motor. All other relevent cables are common to the starter circuit, so you would know from other symtoms if these were at fault.
A long shot is corrosion between the altenator body and the engine block. Came across this once on a big agricultural tractor, where this was the problem, although all bolts were tight, had not been disturbed and looked clean.
Way to test the altenator is to run the engine at about 1500 RPM and measure the battery voltage. Should be between 14 and 15 volts.
Switch the headlamps on - voltage should dip slightly then return to the same.
Does your ignition lamp work? Altenator might not work if this circuit is faulty.
Widge
Post Tue Nov 29, 2005 10:03 pm
I have a spare alternator you can buy if you need it mate. PM me for details.
DaveD
E30Zone Wiki Specialist
Post Tue Nov 29, 2005 10:43 pm
call out the AA and let them do it
e30geezer
Post Tue Nov 29, 2005 10:51 pm
DaveD wrote:call out the AA and let them do it
lol!! at least there good for these sort of things!!
Post Wed Nov 30, 2005 12:11 am
About a year ago, a friend of mine, from about 200 miles away, pulled into my yard out of the blue, with a rapidly dying non BMW.
He wanted to phone the AA to fix it, but I had a quick look, said it was the altenator (brushes), and that I could fix it to last another 1000 miles in about 10 minutes. (By removing the regulator pack and stretching the brush retaining wires slightly).
My friend said he'd been paying the AA for bl**dy years, without getting a penny's worth back, and now that his car had broken down, he was bl**dy well going to make use of them, and would I put the kettle on.
Eventually the AA man turned up, and after watching him makes a right pig's ear of diagnosing the proplem, obtaining the part, and fitting it, I swore I'd never let an AA man near one of my cars.
e30geezer
Post Thu Dec 01, 2005 10:17 pm
Brianmoooore wrote:About a year ago, a friend of mine, from about 200 miles away, pulled into my yard out of the blue, with a rapidly dying non BMW.
same here i dont let them near my cars , just ask em to put it on tow.
ady786
Post Tue Dec 06, 2005 5:53 am
try and starting the car rev it to 2000rpm and take the battery leads off if it dyes out its the alternator
Post Tue Dec 06, 2005 9:11 am
ady786 wrote:try and starting the car rev it to 2000rpm and take the battery leads off if it dyes out its the alternator
And if it's not the altenator, it could well be the engine ECU, the ABS ECU, the alarm, the ICE, and any other electronics on the car after the power surge this will cause. DON'T DO IT.
gcorky
Boost Junkie
Post Tue Dec 06, 2005 10:32 am
ditto definately dont disconnect when running lol 8O
sounds like alternator but before fitting at random do yourself a favour and buy a cheap multimeter and test charge output 14.5v ideally at around 1500 rpm as already pointed out.this will be a useful tool to you in the longterm ! :D
