Diff
calex
Post Thu Dec 20, 2012 3:25 pm
Found a diff in the scrapyard 3.46 will this be any use for my 325 m20? Cheers.
Post Thu Dec 20, 2012 3:27 pm
Probably, if it is a medium case one.
http://www.e30zone.net/e30zonewiki/inde ... fferential
calex
Post Thu Dec 20, 2012 3:35 pm
It's looks exact same as came out.
Post Thu Dec 20, 2012 3:51 pm
In that case, it should be fine. What do you currently have, 3.64 or 3.91?
calex
Post Thu Dec 20, 2012 5:53 pm
Not sure the tags missing and it was on the car when I got it, it was an lsd but the gears are in about 10 bits now.
Post Thu Dec 20, 2012 6:05 pm
Most 325i Sport LSDs were 3.91:1, and a bit low-geared tbh.
Post Thu Dec 20, 2012 8:09 pm
3.46 is an excellent choice of ratio for a M20B25, but if it' replacing a 3.91 you'll notice both a difference in acceleration (bad) and in your wallet (good).
calex
Post Sun Dec 23, 2012 2:14 pm
yeh i put the diff on yesterday and it perfect for that car. The only difference i noticed is in 5th the revs are at 2500rpm at 70mph, the last diff was about 3100rpm so it cruises nicer and bound to be better on fuel on a long run.
Andyboy
Alpina Colada
Post Sun Dec 23, 2012 6:25 pm
That's a rare diff and it would have come from a 323i. A very similar 3.46 diff is fitted to 24v E34 520i's. Swap the rear cover and flanges and it swaps straight over.
Post Sun Dec 23, 2012 8:02 pm
The 320iS also used a 3.46.
