CLUTCH?
calex
Hi, noticed in the last few weeks that the bite point on my clutch is nearly at the top, no slipping in any gears though and seems to pull fine. is it due a change? thanks
maxfield
Bite point is usually at the top with hydraulic clutches in my experience.
Stick it in 4th with the handbrake on (assuming you have a good handbrake) and set of with some revs on. If it stalls all is good. If it revs getting ready for a clutch.
