belt tensioner replacement
Cloggy Saint
Post Fri Dec 14, 2012 9:44 pm
I've read the wiki article on this but think maybe I've got the wrong end of the stick. Should I remove the spring and pin from it's housing before removing the tensioner pulley?
Post Sat Dec 15, 2012 12:10 am
Spring and pin will fall off when you remove the tensioner. The spring pressure is the only thing keeping it in place.
Andyboy
Alpina Colada
Post Sun Dec 16, 2012 2:58 pm
Slacken the 13mm and the long stud, big screwdriver to push tensioner fully back to compress spring and retighten 13mm. I fit a new spring as well, buttons from BMW.
Cloggy Saint
Post Sun Dec 16, 2012 4:58 pm
Cheers guys, new tensioner/spring is waiting to go on.
