m20 idles high when warm?
bmw9818
Post Mon Dec 10, 2012 8:06 pm
got a small issue the m20 idles at 1300 ish when it gets to temp, (manual 2.5)
when its cold its high then drops after 10 seconds to 6-700, it stays there then after it warms up it bounces a bit and settles at 1200,
i cleaned the icv blew it out with air, tps clicks when shut, intake pipe looks good as well, and i take it if there where vacuum leaks it would do it even when cold?
steve_k
Post Mon Dec 10, 2012 8:17 pm
just a thought but have you tested the blue temp sensor as per the guide in the wiki?
i had this type of problem myself once & after following the guide i managed to get it sorted.
