Is there a certain way of removing them from the backrest?
I can get it to pull up to the top of the adjustment but can get it out completely.
Headrest removal on Recaro LS?
maggspower
- Turbo Farmer Tractor Driver
You can only do it when you take the seat apart. There are R clips at the bottom of the 2 vertical runner things IIRC.
I hope you've not been at it long
they have a retaining clip on the underside IIRC, you need to pull the back centre pieces out to remove them
See the 'R' clips here
