m30 misfire and coolant pressure problem
dubownerbilco
Post Mon Nov 19, 2012 5:11 pm
so i have got my m30 conversion up and running
but just having a couple of issues:
when cold the engine is fine and will rev without a problem but as it warms up the misfire becomes more obvious and almost undrivable past 1/4 throttle. i fitted a speedtouch chip and let it tickover for ten minutes as instructed and this made no difference
also after having a brief drive in the car and letting it tickover for a while i noticed that the coolant hoses were rock solid and were visibly larger! all the hoses are connected as per the guide and i bled it without a problem :S
neither of these were issues when the engine was still fitted in the 5, as i used it for a week prior to removing the engine
any ideas people?
thanks in advance
