great back to the garage!
charging rate with heated seats radio hlights heater on full reads in at 9v at the battery and 12 with switched off obv with car on,
connections at alt are tight, thick wire to starter and red wire to alt all tight,
i did accidentally drop the alt from a height of about 3ft?
could it be the voltage pack as its arced in with the old 316i alt and not brushing properly?
