Removing sunroof from my 325i sport
lisa325is
Post Sun Nov 11, 2012 6:21 pm
Hi there was just looking for some advice and easiest way of removing the sunroof from my car as its going to get painted...thanks..
maggspower
Turbo Farmer Tractor Driver
Post Sun Nov 11, 2012 6:35 pm
Slide it back, prise down the clips in the fabric at the front, there is about 5. Slide the fabric part back. Then slide the roof forward and tilt it up, you will see 6 torx head screws, 3 on each side, holding the tabs of the sunroof. Make sure you have the right tools to undo these, as if you round them off you are going to be in the sh1t :D Once these are undone the roof will lift out.
Be careful with the seal the are now £80 from the dealers 8O
lisa325is
Post Sun Nov 11, 2012 11:19 pm
Thank u very much matey!!!will av to lift this out tomorrow!!thank you!!!!!!
