IS AWFUL!.
struggled with the removal of the screw holding the valve to the core, but now i can't get my hand in a decent enough position to slacken the bolts holding the pipe to the valve!
Any tips?
cheers
Heater matrix replacement
yung-gun
oomz1975
yung-gun
iceox
you have to undo them from the engine bay, did mine with the engine out, so i'm not to sure you can do it with the engine in? i think its 8mm or 10mm, use a ratchet with a exstension and wiggle it in there, then get it on the nut. its all done by feeling, you cant see fuck all
yung-gun
oomz1975
yung-gun
Bit of PVC insulating tape around the flange to hold the square nuts in place when you refit.
Replace the cross head self tapper behind the brake linkage bracket with a hex. headed one to make reassembly and future dismantling easier.
8mm bolts can be reached with a 1/4" socket and extension from under the bonnet and through the rubber grommet.
yung-gun
suedenim
I remove the servo bracket. Upon refitting make sure that the brake pedal at rest is pressing the brake light microswitch, you can hear it click when it engages. ^^ Same method for the screws facing the bulkhead, extension through or remove the grommet.
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
yung-gun
