Suspension
nav786
Post Fri Nov 25, 2005 9:39 pm
right guys need to know if the suspension on my car will be ok for a 2.5 lump. my cars a 1.8 but with spax springs and suspension. so will it work once i do the conversion?
FOR SALE
SONY PSP'S £100
tylerma
Post Fri Nov 25, 2005 10:04 pm
gonna move this to tech help Nav
might get a little more help in there
nav786
Post Fri Nov 25, 2005 10:10 pm
cheers mate, thought i was in tech sect when i posted :oops:
FOR SALE
SONY PSP'S £100
M5pilot
Post Fri Nov 25, 2005 10:44 pm
Front suspension will be different, rears wont need touching.
Get some H&R /Koni Bilstein stuff in there. Youl feel a massive improvement in ride over the spax with same or better handling.
JimmyC
Post Fri Nov 25, 2005 11:40 pm
heavier springs will be needed at the front for the extra weight
can sort you a deal on some coilovers if your looking at buying NOW
Jimmy
nav786
Post Sat Nov 26, 2005 1:49 am
would i need to change the whole suspension to the 325 setup. as the strut is wider or summin.
FOR SALE
SONY PSP'S £100
jonbuoy
Post Sat Nov 26, 2005 12:47 pm
nav786 wrote:would i need to change the whole suspension to the 325 setup. as the strut is wider or summin.
Would be better off doing that mate, especially if you have'nt done the brake conversion to the vented disc's. It won't cost alot to change it over to the 325 setup, remember it's just the same as the 320 setup so don't turn one down! You might be looking at about Ԛ£30-Ԛ£50 a side at the breaker's and you'll get the whole lot :D
Good luck with it mate :thumb:
Demlotcrew
Post Sat Nov 26, 2005 12:51 pm
If your talking about the car in your pic, then it will have all the bigger parts from factory, so wont need any changes.
Andrew
nav786
Post Sat Nov 26, 2005 2:08 pm
yeh andrew the car in my sig, its a 1.8 so how comes it will have the bigger parts? i have upgraded the suspension already to spax springs and shocks.
i know the brakes need changing as there not vented ones.
cheers.
FOR SALE
SONY PSP'S £100
Demlotcrew
Post Sat Nov 26, 2005 2:19 pm
I thought that all Cabs came with disks all round and Vented at the front with 51mm struts, unless someone has taken those parts from your car.
Andrew
nav786
Post Sat Nov 26, 2005 9:26 pm
it has discs all round but not vented. none of the 318i cabs do... dunno.
not sure about the struts tho.
FOR SALE
SONY PSP'S £100
