I have a HLWW kit and heated washer jets that I need to fit to the car. The plugs for the water pumps are all broken and on some of the plugs the wiring has also broken.
I was onto the dealer about new plugs using the part no's on the plugs for the pumps but not much joy.
61 13 1 378 418 - this one is from the plugs and not available
61 31 1 378 406 - this one is the femal plug (I think)
Does anyone know is there a replacement part no? And also the part no's for the wiring connectors as I need a few of those also and I have no plug on my heated washer jet loom if anyone knows it?
Plug part no's for HLWW & Heated washer jets
Jozi
Jozi
Anyone know the replacement part no for 61 13 1 378 418 this is the plug used for the pumps on the washer bottle and also the side light.
bab-91
61121380673 - wiring loom
IG - bab91
IG - bab91
Jozi
No point buying a new loom really. I'm re-routing all the wires around the bay and would need to chop up a good new loom to do what I want which would be a waste.
I found a guy who has the NLA plugs
I'm missing the plugs as in this picture:
Does anyone know where the male and female plug go?
Jozi
Anyone know where the two plug connect into?
DHFiS
they connect between the loom and the screen washer pump
Jozi
You wouldn't happen to know how the plugs are wired? I found a pic showing both plugs get the purple and brown wires but I'm wondering are they looped somewhere?
DHFiS
I can take a pic tomorrow if you dont get an answer tonight.
Jozi
Thanks DHFiS. I think I may need to go figure out how to read wiring diagrams, I know where they coonect now but not sure how it's wired properly or got my head around that bit.
