hot starting issue advice please
gmf_uk
Post Mon Nov 05, 2012 4:33 pm
when my engine is cold it starts fine every time, but once hot the first time i try to start it it turns over fine but wont fire, then when i turn the key the second time it fires straight away. this happens 90% of the time when the engine is hot. Where should i start looking, Thanks
Rtaylor2208
Post Mon Nov 05, 2012 4:41 pm
1st thing to do is test the blue temp sensor at the thermostat housing / ECU. Search the wiki for blue sensor and a full guide is detailed on how to do it.
gmf_uk
Post Mon Nov 05, 2012 5:05 pm
will do thankyou
