Now it probably doesnt but , the other week i ha a bolt come out and disapear from the prop donut , i replaced it with a random nut n bolt n washer ?
I say this as since them im experiencing vibrations an i only replaced the donut 6 month ago but tbh i rekon its fooked due to having to drive 25 mile home at 40mph with one bolt missing
Will it matter
BATTS91
Nut and bolt need to match the others for weight, and the bolt should be a very high tensile 10.9 grade.
You may have damaged the doughnut, or possibly the centring spigot/bearing that keeps the prop in line with the gearbox output shaft.
BATTS91
Ok thanks brian , the weight of bolts never crossed my mind . Spose ill have to go see bbb for one, and go from there
