exhaust problem ? :(
baxter-e30
Post Fri Nov 02, 2012 7:36 pm
i recently bought a scorpion twin exhaust system to replace my standard system on my 318i as it is knackered. i was going to fit it tomorow if weather is decent but the problem is when ive looked at the scorpion exit pipes, it looks like they are going to be too big for the exhaust exit.. whats the best way to go about it this?
i kinda dont want the backbox to sit daft below the standard exhaust exit.
cheers, for any help
Post Fri Nov 02, 2012 8:13 pm
you have to cut the rear valance .
baxter-e30
Post Fri Nov 02, 2012 8:18 pm
magpie wrote:you have to cut the rear valance .
best thing to cut it with?
Post Fri Nov 02, 2012 10:04 pm
A nibbler is probably the best tool for the job, but it'll depend on what you can get your hands on. Small disc grinder and a jig saw will also do the job.
Probably a good idea to take measurements from a six cylinder E30 valence to get the cut where it should be.
baxter-e30
Post Fri Nov 02, 2012 11:42 pm
Brianmoooore wrote:A nibbler is probably the best tool for the job, but it'll depend on what you can get your hands on. Small disc grinder and a jig saw will also do the job.
dont suppose anyone on here could measure their 325i valance (exhaust exit) pleaaaase!!
Post Sat Nov 03, 2012 8:48 am
i used a small grinder then a dremmel . right angles are a no no here .
draw the shape you want on the valance first,i done mine by eye then had to give it a tiny trim as it was catching mainly on bumpy roads/tracks ,i wanted mine as close/small as possible to keep it neat and tidy looking.I treated the bare metal with rust remedy then under-sealed the whole inside if the valance and waxoiled over the under-seal .
pac1982
Post Sat Nov 03, 2012 9:28 am
make sure you reseal and bare metal afterwards, the rear valance is a known rust spot anyway dont want to make it any worse
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
