E30 headlights
Racer75
Post Fri Nov 02, 2012 5:39 pm
My e30 isn't used very much any more. She is still started and looked after but as I'm 17 and learning to drive she isn't used in favour of a smaller engined car. I noticed the other day that the offside headlights weren't working and i was curious as to whether that will be a result of the car being sat up.
Cheers :cool:
pac1982
Post Fri Nov 02, 2012 5:56 pm
bit of a hard one to say really without seeing the car to tinker with, i take it you have checked your bulbs and connections?
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Post Fri Nov 02, 2012 10:34 pm
Car not being used shouldn't affect the headlamps, unless there's some developing corrosion somewhere.
Both main and dipped beam lights not working?
Racer75
Post Sat Nov 03, 2012 12:45 am
Newly fitted superwhite bulbs. Driverside fine but passenger side not working. Will have to check connections in the daylight, is there anything to look for in particular guys?
Post Sat Nov 03, 2012 9:19 am
Brianmoooore wrote: Both main and dipped beam lights not working?
pac1982
Post Sat Nov 03, 2012 9:27 am
Racer75 wrote:Newly fitted superwhite bulbs. Driverside fine but passenger side not working. Will have to check connections in the daylight, is there anything to look for in particular guys?
if your bulbs are new could just be a faulty bulb, especially if they are cheapo chinese jobbys off ebay
Racer75
Post Sat Nov 03, 2012 9:12 pm
Main beam works but not dipped beams
jimbob29
Post Sun Nov 04, 2012 12:57 am
Have a look a the wire that clips on next to the bulb clip
