How to undo prop with diff already removed?
rossmc88
Fri Oct 26, 2012 10:14 pm
anyone know how to undo the prop to gearbox bolts when the diff has already been removed?
I really should have undone these bolts before I sold the diff
I tried locking the engine using a spanner on the viscous coupling, but it doesn't lock it
Any help would be great!
kam-325i
Fri Oct 26, 2012 10:15 pm
Large screwdriver thru the U joint to lock it against the car....
bmw9818
Fri Oct 26, 2012 10:19 pm
^ +1 or airgun it,
Fri Oct 26, 2012 11:33 pm
22mm socket on the crank nose bolt and bar against the chassis rail will stop the engine turning, but you're still dependant on the clutch not slipping.
rossmc88
Mon Oct 29, 2012 8:29 am
kam-325i wrote:Large screwdriver thru the U joint to lock it against the car....
This did the trick! Thanks!
Mon Oct 29, 2012 10:05 am
Spanner on one end, socket and ratchet on the other.
No need to lock anything.
