Heated Washer Jets Temp Sensor
Jozi
Does anyone have a part no for this, I have the nozzles and cabling but no sensor.
Are they not on all the time? Like the mirrors
Jozi
You might be right actually, I was just going through the pdf in the wiki and seen it mentioned, it's not listed though. http://www.e30zone.net/e30zonewiki/imag ... r_jets.PDF
I wonder can a switch be retro fitted?
Grrrmachine
- E30 Zone Wiki / Team Member
Heated washer jets piggyback onto the washer pump feed. Based on that, I think they're only powered for as long as the washer pump works. Certainly no sensor on the loom I just fitted.
However, that PDF in the Wiki talks about retrofitting E36 jets to an E30, and in that case there may be a sensor included.
Jozi
Is there meant to be a plug on the loom then? I just have 3 wires, 2x purple and brown, can I just splice them in then on the plug powering the pumps?
Any idea where the sensor would be located on an E36? As ive never noticed one TBH
Jozi
Going by the pdf it's on the brake duct or on a bracket.
Slightly related to this, where will I find the plug that goes onto the level sender on the washer bottle? I don't think it's on the HLWW loom and I don't see it on the loom going around the engine bay, all I have for this is just 2 pins sticking up on the bottle.
Grrrmachine
My factory heated jets have a male and female plug for the washer jets. You unplug the washer pump feed, plug it into the washer jet loom, and then connect that loom to the washer pump.
God knows how the E36 setup works, but it definitely includes a temp sensor
Jozi
This is what my loom looks like:
Anyone know what connector goes on here and where to find it?
Topblag
is that not the washer level sensor ?
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Jozi
Yeah, but where's the plug thats meant to go onto it? What part of which loom should it be on?Topblag wrote:is that not the washer level sensor ?
penton08
In the drivers side brake duct. It is a metal disc looking thingDanThe wrote:Any idea where the sensor would be located on an E36? As ive never noticed one TBH
