removing throttle cable and adjusting
bmw9818
Post Sat Oct 20, 2012 8:16 pm
how would i go about removing the throttle cable its a 316i?
lots of grease on the tab, and is there anything that is prone to breaking when removing or installing,
dont want any surprises as car needs to be done by friday,
thanks
Billwill
Post Sun Oct 21, 2012 10:35 am
No big deal in replacing...unhook it from the throttle pedal...tape the new cable onto the old cable so it is easy to pull through from the engine bay. In the engine bay you have to remove the black plastic assembly clipping the cable to the throttle linkage.
If I remember correctly there may be a bolt holding things in place where the cable assembly runs through the bulkhead.
The new cable assembly will have the inner cable sheathed in a Mylar-type coating but I think it is worth spraying a bit of Silicone lubricant down into the new assembly first. :)
