clutch replacement time 1990 318i
rotta
Post Wed Oct 17, 2012 10:48 am
as the title says chaps what is the recommended labour time for clutch replacement on a 1990 318i..
Many Thanks
Rotta :D
milescook
Post Sat Oct 20, 2012 10:52 pm
I paid 500 all in for ny 320 clutch that's a local back street garage :'( they said it tookl them longer than they thought it would.
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
maxfield
Post Sat Oct 20, 2012 10:57 pm
Depends on how competent you are, tools etc.
If your on your axle stands with limited tools I'd allow a day.
Otherwise on a ramp with plenty of tools it's only a couple of hours to do one.
bmw9818
Post Sat Oct 20, 2012 11:21 pm
its a bit long...
exhaust off, heat shield off prop bolts off, crossmember bolt, gearbox bolts starter, need a clutch centering tool, it can be done in a day at home,
need to make sure the jack is good though... benching a gbox on the floor up to the engine isnt something id enjoy, and if it drops off the jack... id just get it done at a garage
Billwill
Post Sun Oct 21, 2012 10:23 am
I have done it myself...as stated it is a bit of work but you can do it yourself in one day.
Make sure you mark the prop shaft carefully before taking it off/apart.
You need a trolley-jack to take the weight of the gearbox so you can drop it or raise it to the correct height.
You also need the correct Torx female sockets and a long extension and universal to get to the Torx bolts on top of the bell-housing.
New clutch kit should come with a plastic centering tool hopefully. :)
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Oct 21, 2012 11:08 am
There is a clutch guide in the Wiki:
http://www.e30zone.net/e30zonewiki/inde ... ing_Clutch
but it is biased towards having the engine out at the same time.
