Ideas on drop with rear b4 bilstein shocks.
- cherryredbenj11
Hi i just wondered what kind of a drop on the rear i'd expect with b4 bilstein shocks on standard springs? does anyone maybe have a picture of theirs or the shocks and lowering springs? thanks.
pac1982
a damper has nothing to do with the ride height of a car so an E30 using billy dampers and standard springs would look the same as a car on standard dampers
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Rtaylor2208
No drop, the springs control the drop not the dampers.
- cherryredbenj11
How come the recommended drop with bilstein dampers are only 40mm?
because of the length of the dampers - B6's IIRC have a shorter damping rod to allow for a bigger drop - however much more than 40mm will be impractical and horrible for normal road use anyway.
- Brianmoooore
Because that's about as far as you can go, and still have suspension that works properly.cherryredbenj11 wrote:How come the recommended drop with bilstein dampers are only 40mm?
