Exhaust manifold/down pipe nuts
anothere21323i
Post Sat Oct 13, 2012 7:20 pm
Hello all, hopefully somebody can help me out with this one!
I'm currently in the process of removing the exhaust manifold from my 91 325i Touring, because the gasket/heat shield is knackered plus there's a broken stud in there.
I've finally managed to get all the manifold bolts off, and have got 3 of the 4 manifold/down pipe bolts off. But the 4th one is tucked away right to the rear of the manifold, close to the block.
Herein lies the problem - I can't see any way of getting a socket or a spanner in there because its so tight.
Any tips?
hennabm
Post Sat Oct 13, 2012 7:30 pm
The 4 stud type downpipe is doable from underside with several extensions and a UJ (universal Joint) in the line as well.
I normally use a 1/2 drive ratchet, UJ and extensions for this job to get the leverage required to undo the little ****
I would tighten the manifold to the head again with a couple of nuts,just while you undo the downpipe nuts, so it is secure.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
