idle issue/ vacum line identification
mdw
Wed Oct 10, 2012 10:12 pm
I've got a 316 m10 running on the original carb. Once its up to temperature it idles erratically, with revs rising and falling.
Any ideas what this could be?
I cant find any leaks on any vacum lines , however one of the vacum lines doesn't go anywhere, it leaves the carb then joins a plastic disc but this isn't connected to anything. Is this correct?
mdw
Sat Oct 13, 2012 1:04 am
anyone got any idea what the problem could be?
capnmchl
Sat Oct 13, 2012 9:08 am
Pictures of this vacuum line, and car mileage.
The pierberg 2BE carb is a pile of crap. It as electronic idle, electronic choke and electronic 2nd barrell, so I expect it's one of those playing up.
You're best off spending £300 and getting the Weber replacement carb, a DMTL32/34, which is designed and jetted for this car.
Or if you're feeling brave, a Weber 32/36DGV.
teamalsoran
Sat Oct 13, 2012 11:16 am
capnmchl wrote:Pictures of this vacuum line, and car mileage.
best thing you can do, i have fitted loads of these over the years, it usually transforms the car :)
only downside is the econometer thiungy wont work afterwards and your have to find somewhere to mount the choke cable
mdw
Sat Oct 13, 2012 12:56 pm
milage is only 60,000
this is a pic of the line with the plastic disc
I know the pierburg is crapbut just want to get it running a bit better for now.
mdw
Tue Oct 16, 2012 9:39 pm
Anyone have any ideas?
DHFiS
Tue Oct 16, 2012 10:11 pm
I had a carb on my first E30 and it had so much wear in the moving parts it wouldnt run cleanly. A Weber carb cured the problem.
