Appears to be the TPS connector.
Now, considering that all the TPS modules I've seen, and the one I've got, have oblong connectors with three pins - and this is round and has 6 pins - I guess I'm missing something, right?
Ta,
Jason
Or find a TPS from a switchable auto. The extra three pins are for a throttle position potentiometer, similar to that used on the iS and later BMW engines, instead of a throttle position switch. In this application though, it's just used to give throttle info. to the gearbox ECU.GreatOldOne wrote:Bugger. My M20 is manual... Guess it time to get the soldering iron out...
