Headlights
My headlights (dip) are amazingly dim, so much so that I put 100w bulbs in and this seemed to make little difference.
So....
I ordered some "head light units" from gsf - and when they arrived all that they contaned was the glass part of the lights - I wanted the whole lot.
Good old gsf happily refunded me and even seemed suprised they didn't stock the whole thing.
So....
I phoned BMW today, who told me it's Ԛ£245 a side. I presume this is for the main beam aswell, but seems so expensive.
My questions - Where can I buy new dip units cheap?
Can the old ones be reconditioned?
Would second hands ones be ok? and does anyone have any?
Pete
So....
So....
Pete
6potWil6pot
Im no sparky but either the reflective bits on the back of your lights are busted or your wires are worn out or something. You can always get 2nd hand headlights for little if you want to test em.
Simon
- Contact:
What type are they? Early metal bumper type, or are they the projector type with/without smiley?
I find a good clean out can work wonders, I took mine off, and filled them with soapy water and then let them dry, and then cleaned all the accessible reflective parts of the light. I then bought some phillips blue vision bulbs and the difference was very noticeable!
Simon
- Contact:
They give a nice crisp white light and they are the legal 55w bulb too....johnono wrote:si, are those phillips bulbs blue or white when they light up, and r they 55w or 100w
they look purple in this pic mind!!
Simon
- Contact:
The sidelight bulbs are 5w phillips blue vision bulbs too, they came free with the dipped beam bulbs.johnono wrote:lookin goood there myman!! did u use leds for the position lights or are they bulbs too. also if i wanted to do the fogs, how big a deal are we talkin
What do you want to do with the fogs? Clean them you mean? If so yes just as easy, remove them and fill with soapy water give them a shake!
Simon
- Contact:
Ah sorry, got you now!johnono wrote:no , i mean, if the side lights, positions and main beams are white white, itԚ´ll look a little odd with yellow fogs, are there bulbs i can use on them too?
Yes they sell the H3 bulbs too!
Demlotcrew
Yellow fogs are so cool!johnono wrote:no , i mean, if the side lights, positions and main beams are white white, itԚ´ll look a little odd with yellow fogs, are there bulbs i can use on them too?
and very functional
Demlotcrew
johnono wrote:not as cool as your siiiig , mmmmm
cheers si , so i need
* pair of H1 sidelights 55w
* pair of little blues ( ill find out the watts)
* " " main beam bulbs (H1 or H3?)
* " " H3 for the fogs
im sure thatԚ´ll cost a bit but they look worth it
Demlotcrew
Full beam are also H1.
Andrew
Andrew
Simon
- Contact:
Sidelight bulbs are 5w caplessjohnono wrote:cheers si , so i need
Main beam bulbs are H1 also.
Demlotcrew
I do like the white cars just something about them, like Roys are just amazing.johnono wrote:sheԚ´s a beuty!
Andrew
Demlotcrew
hes too busy fitting Air con.
White is a very nice colour! Red, White and Diamond black are my fav
Demlotcrew
oh yeah
Well i got two just need a white M3 now.
- Brianmoooore
Getting back to headlights - the reflective bit on projector dipped beams don't do anything - they're just there for the sidelights.
If they are dim, first thing to do is measure the voltage actually at the lamps, and to check there is no significant voltage between the brown wire at the lamps and the car body/battery neg.
Demlotcrew
Well they do actually, they are there to prevent glare from the Projector escaping. (im sure it called a shroud)Brianmoooore wrote:Getting back to headlights - the reflective bit on projector dipped beams don't do anything - they're just there for the sidelights.
Andrew
A1BMW325iSport
- Contact:
Johnono - i`ll be going the same route as you with the bulbs mate.
Simon - thanks for the info on the bulbs
Matt
Matt
- pm9575
As well as Philips - check out Osram 'Silverstar' (German made):
This H1 55W packs a bright white punch with no side affects on the electrics.
The price may also be more favourable than the Philips type.
pm9575
pm9575
