Central locking problems please help !
shane281189
Post Thu Oct 04, 2012 5:55 pm
I've jus brought a cab and the central locking ain't working , I've had to have a alarm put on this week for insurance purposes and they couldn't connect the central locking with out it working grrrr so gunna have to pay to get that wired in after !! But what I've done in took the relay from behind the door speaker to find it had some water damage and the thermal resister thing had unsoldered so I borrowed a mates one that is working but still nothing ? Any ideas ? The plug has green corrosion in it how do I clean with our damaging it or does it need a new plug ? Any help would be great
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Oct 04, 2012 6:40 pm
Post Thu Oct 04, 2012 6:41 pm
Have you carried out the £Red/black" wire mod on this yet???
If not, look for it in the WIKI section.
Post Thu Oct 04, 2012 9:23 pm
Probably a good idea to work out why the sill drain slots didn't do their job, and allowed water to damage the locking ECU before you replace it.
Sadly, if the locking ECU gets wet it tends to apply power to all the lock motors continuously, instead of just a brief pulse, resulting in a full set of burnt out motors.
After doing the red/black wire modification, I recommend you test the lock motors using wire links in the ECU socket, before you refit the ECU, to see if this has happened.
The fusible link in your existing ECU isn't intended to be repaired, but if you do, it's important that you only do so with the existing solder, which is a special low melting point type. DO NOT add ordinary solder.
