Due to having discovered that the original tail light gaskets were useless, I decided to give the gaskets a bit of a clean whilst waiting for the new ones to arrive and took the opportunity to have a closer look inside the boot.
I was well aware there was water in the left arch, hence why I ordered new gaskets. However, I took a look at the right hand one, where the battery is as I saw just a few drops of water. I checked all around the tailights and saw no rust, so I decided to take out the battery and found that the inside arch was rusting away.
I'm guessing this needs my immediate attention! Does anyone have any reconciliations on what I should do next! My initial thoughts are to completely take the carpet out of the boot and have a good thorough look at what other mysteries the can be in there...
View from the outside
View from the inside
