removed the block from a 325 track day car.. its going into mine basically when i removed it i noticed there were 3 washers on either mount?
the car had a e36 rack with standard e30 coupling so im thinking po has raised engine for clearance..
when removing exhaust system etc i didnt notice any issues with height or distorted joins it looked fairly normal,
there seems to be enough thread on the top bolt, so am i likely to run into any other issues, it worked fine in the other one but underbonnet foam wasnt there anymore so coudnt say if it was touching?...
Engine mounts had spacers on them?
maxfield
I'm fairly certain I had to put a couple of washers under my engine mount to get clearance on my e36 rack. Ran my car for a year without issues like it
