dashboard bulbs
juser
Post Sat Sep 29, 2012 1:45 pm
Any one know what these are or where to get from...
greg124
Post Sat Sep 29, 2012 1:49 pm
pm sent
Schadenfreude - the German's haven't got a word for that.
Post Sun Sep 30, 2012 9:48 pm
The code for these bulbs is 286. Readily available on ebay and anywhere else you'd expect to find automotive bulbs. 12 volts 1.2W.
juser
Post Sun Sep 30, 2012 9:59 pm
sweet thanks! I got some from Maplins, but I'm sure that my dash board isn't very bright for some reason
TPS
Post Sun Sep 30, 2012 10:02 pm
Stupid question, Is the Brightness control on the Headlight switch working?
juser
Post Tue Oct 02, 2012 9:15 am
Brianmoooore wrote:The code for these bulbs is 286. Readily available on ebay and anywhere else you'd expect to find automotive bulbs. 12 volts 1.2W.
Cheers mate, do you know if these are the same bulbs that are inside the instrument cluster? When I'm driving at night, the panel is barely visible... I'm guessing this is to do with the lights been old and black throughout the years....
juser
Post Tue Oct 02, 2012 9:16 am
TPS wrote:Stupid question, Is the Brightness control on the Headlight switch working?
Do you know what... I don't think I have one? I've not spotted it... Where about is it??
Post Tue Oct 02, 2012 9:39 am
The bulbs that light the cluster are physically larger than the other bulbs, and are rated at 3W.
5W versions of these bulbs are commonly used as side light bulbs, but if you fit these, the heat from them WILL melt things in the cluster. You need to use the correct 3W ones.
If you have an E30, then you will have the dimmer control! Try rotating the lighting switch knob.
capnmchl
Post Tue Oct 02, 2012 9:56 am
Took me ages to find that out. I just thought it span round for no reason.
Are those black strips above the headlight control and foglight switches meant to light up or something then?
Post Tue Oct 02, 2012 10:09 am
capnmchl wrote: Are those black strips above the headlight control and foglight switches meant to light up or something then?
Yes; there's a 1.2W capless bulb that lights it up, that should be lit all the time the ignition is on.
juser
Post Tue Oct 02, 2012 10:46 am
Amazing... Like capnmchl I thought that span round for no reason... I did though notice that the black strips were meant to light up! 8)
capnmchl
Post Tue Oct 02, 2012 11:51 am
Haha. I had a feeling they did because you can see the outline of a foglight symbol and sidelight symbol. I'll rip mine out today and replace the bulbs.
juser
Post Wed Oct 03, 2012 1:58 pm
Stupidly enough, I since then looked for the brightness control, turned it fully to the right and voila, my lightbulb problems have all vanished. Thanks again for your help!
