bmw e30 m42 engine swap,can't start up.
saluts84
Post Fri Sep 28, 2012 9:29 pm
Hi,i swapped an engines on my e30 from m40 to m42 out off e36,all the wiring loom is from e30,ecu is from e30,so there is a problem-the engine turns over,but there is no spark and the fuel is not coming to the engine.
MrWhite
Post Fri Sep 28, 2012 9:34 pm
Have a search in the technical forum. I had engine swap troubles with my M42, it turned out to be stuck injectors but it took a few steps to get there.
rust never sleeps
TPS
Post Fri Sep 28, 2012 9:42 pm
Crank Position Sensor?
Post Fri Sep 28, 2012 10:19 pm
IF you're certain there is no spark and no fuel pump activity when cranking, then the problem is either the CPS, as above, or whatever you've connected up wrongly.
saluts84
Post Fri Sep 28, 2012 10:26 pm
I checked crank position sensor 500 ohms I tried another one and was the same 500 ohms and same nothing.
saluts84
Post Fri Sep 28, 2012 10:29 pm
I checked all connections many times
johnl320
Cam and crank sensors plugged in the right way around?
saluts84
Post Fri Sep 28, 2012 10:30 pm
is it crank sensor plugs in the bottom and cam sensor on top
johnl320
Post Fri Sep 28, 2012 10:33 pm
As far as I can remember will check in the light tomorrow if you want? Brian probably already knows though.
saluts84
Post Fri Sep 28, 2012 10:36 pm
thank you, that would bi helpfuly
saluts84
Post Sat Sep 29, 2012 9:27 am
yes, but I use e30 318is wiring loom, ECU 175, inlet manifold. basically everything is e30 except bare engine and crank /cam sensors.
Post Sat Sep 29, 2012 10:23 am
Engine relays in the right sockets?
Check, with a 12 volt bulb NOT a meter, that you have power at the green wire of one of the coil pack plugs with the ignition on, and when the starter is engaged.
saluts84
Post Sat Sep 29, 2012 1:36 pm
I did and bulb did go on when ignition is on and when the starter was engaged.
Any more ideas?
saluts84
Post Sun Sep 30, 2012 7:33 pm
Problem sorted! I did ecu reset and engine get started straight away!
Thank you for your help!
