weight difference ?
gooseygander110
Post Thu Sep 13, 2012 12:45 am
Does anyone know the weight of a M30B35 engine ? ta
Post Thu Sep 13, 2012 8:37 am
Im not sure exactly but I believe it should be measured in displacement tons :D
gareth
Post Thu Sep 13, 2012 9:01 am
That's rude. Just like a lady, you should never ask a M30 it's weight :P
suchy
True Zone Relic
DanThe wrote:Im not sure exactly but I believe it should be measured in displacement tons :D
Hahaha :D
Best way to work out the displacement is to divide the area into easier sections and work out the volume that way. You then multiply the total volume by 63.4 (weight of water in psi) Ask Rav as he declared his M30 conversion so will have already been through this process :thumb:
gooseygander110
Post Thu Sep 13, 2012 12:29 pm
It was just a matter of interest (and suspension adjustment) because I am putting in the M60 v8 which I know is all aluminium and 203kg regards
Gus
