What should the idle be set to once warmed up? And the next question is .....what's the best way to adjust it?
Chris.
M20B23 correct idle speed when warm?
Andyboy
- Alpina Colada
Set it to 800 rpm. There is an adjuster screw (air screw) on the alloy casting that bolts to the inlet manifold directly above the cam cover.
