Speedo not working 325 touring
cherryredbenj11
Post Sun Sep 02, 2012 10:03 pm
Hi, i have a problem with my speedo, it doesnt seem to work everytime i put my foot down, sometimes it works when the car is in gear and i let of the throttle, it sometimes bouncers around too if im using very little throttle, when the speedo isnt working the mpg gauge wont either but it starts to read also when letting off the throttle? Anyone had this problem?
maggspower
Turbo Farmer Tractor Driver
Post Sun Sep 02, 2012 10:12 pm
More than likley the wire from the diff, the vibration that it is subjected to cause it to break up internally. Unplug it and replace the last 30cm of it.
petchy
Post Mon Sep 03, 2012 5:17 am
maggspower wrote:More than likley the wire from the diff, the vibration that it is subjected to cause it to break up internally. Unplug it and replace the last 30cm of it.
/\ what he said.
Also check/clean the plug at the same time. My old 318i had this problem.
