crunch from suspension?
Captain_Birdseye
If I have 2 passengers in the back and go over bumps I get a crunchy scrape sound. What is it?
Grrrmachine
- E30 Zone Wiki / Team Member
The packet of Quavers they had in their back pocket?
Could be anything. Low hanging exhaust from worn rubbers or broken mounts, rotten rubber spring pads allowing the springs to grind on bare metal, the dampers bottoming out...
Captain_Birdseye
Definatley not exhaust. Second 2 probs? Hmm... next project a brewing!
HairyScreech
Got mud flaps fitted?
Green
Wheels rubbing arch inners? Check the inners and see if you've smooth/clean bits
Captain_Birdseye
will check the inners, cheera. It only has 15's on it though and with the lower profile tyres the total diameter is less than 14's with fat tyres.
