Windows are covered in the wiki. Rear covers are easy, remove the door seal. Remove the lower part of the rear bench, remove the speaker covers being carefully of the clips, there's a few screws behind he covers then the rear panels come off.
For the handbrake remove the centre console, there is a small plastic nut under the rear ashtray, loosens the handbrake cables at the handle end.
If you need to remove the disk remove the small hex retaining bolt on the disk and tap the disk off from the rear using a rubber mallet.
Need help, Cab Windows and other bits and pieces.
Rtaylor2208
