Diff ratio
scjimbo
Post Fri Aug 17, 2012 8:43 pm
I have a pre facelift 320. I'm looking to buy a diff to renovate off the car then put on to replace mine.
What's a good ration to get, and indeed any ideas what ration mine would be as standard.
CIA
scjimbo
Post Fri Aug 17, 2012 9:07 pm
Further to the above at this juncture I have to admit I know diddly squat about diffs. When i say ratio I mean 3:64 or whatever it is. :mad:
vokietis
Post Fri Aug 17, 2012 9:10 pm
prefacelift might be 3.45 ratio
jmc330i
Post Fri Aug 17, 2012 9:26 pm
Pop your VIN (usually last 7 digits) into realoem and it should only list the parts for your car, you can then see what ratio it left the factory with.
James
'91 325i Sport
'93 318i touring 16v
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Aug 17, 2012 9:34 pm
scjimbo
Post Fri Aug 17, 2012 9:40 pm
cheers grrrrr
scjimbo
Post Fri Aug 17, 2012 10:44 pm
I've heard the ratio is cast into the diff. Where abouts is it on the casing?
AlpineCab
Post Fri Aug 17, 2012 10:48 pm
there should be metal tag on the diff case. give it a clean up and reveal the number!
Duke137
Post Fri Aug 17, 2012 10:53 pm
scjimbo wrote:I've heard the ratio is cast into the diff. Where abouts is it on the casing?
Not true, it is a little tab on bolted to the back plate, 30% of the diffs I have don't even have one and the rest are unreadable without a wire brush on a drill :)
scjimbo
Post Wed Aug 22, 2012 7:23 pm
jmc330i wrote:Pop your VIN (usually last 7 digits) into realoem and it should only list the parts for your car, you can then see what ratio it left the factory with.
Right I got my V5 back today from DVLA so put the details into real oem. Really not sure if I'm using it right. I go through to the parts list after I put in my number to my diff. Its not giving me the ratio but it is saying I have a limited slip diff and i don't get any other options. Is this possible on my car. Pre face lift 320 2 door?
CIA
