dif cover gasket change
e30-EVN
Post Tue Aug 14, 2012 1:35 pm
Can a 17mm ring spanner be used for the 2 top dif cover bolts to remove the dif Backplate?
Or is it a case where the dif has to be dropped to acsess them? I can get to the rest but not these 2. Why the fcuk did they put them there?!!!! :x
T I A
Post Tue Aug 14, 2012 4:03 pm
are you jacking the car up from the beam or the diff ?
the backing plate is easily removed with diff in situ normally, :?
e30-EVN
Post Tue Aug 14, 2012 4:29 pm
Mick... With the car in the air and an axle stand under the beam I cannot get a socket on the top 2. The top left one is even more in acsessable than the top right. There is the ridge that the dif mount carrier is welded to that runs across the width of the Car,,, it is this that is in my way!
Sanchez
Post Tue Aug 14, 2012 4:38 pm
Use 2 ring spanners.
One on the bolt and the other through the C part as more leverage. No socket will fit with beam on the car, but as mick says you can change the gasket with the diff on the beam.
e30-EVN
Post Tue Aug 14, 2012 9:56 pm
I thought a ring spanner would do it. Will borrow one tomoro
Cheers lads
Post Tue Aug 14, 2012 10:07 pm
You shouldnt have anything propping the car under the beam, this is why you cant get at the bolt, put the axle stands under the sills, or under the beam bush bolts and the diff will drop slightly with the hanger bolt out.
Recently renewed beam bushes can end up being pushed out of the beam by sitting the car on axle stands under the beam, I changed a beam recently that had twisted due to being unknowingly driven with the bushes hanging out
e30-EVN
Post Tue Aug 14, 2012 10:11 pm
Right I shall try this tomorrow ramm cheers mate.
Post Tue Aug 14, 2012 10:16 pm
Give me a ring tomorrow if you want a word about the cooling mate :wink:
e30-EVN
Post Tue Aug 14, 2012 10:33 pm
Yes please mate. Thanks
e30-EVN
Post Wed Aug 15, 2012 12:36 pm
Got myself an 11/16 ring spanner today and guess what......... Its p i ssing down!
Got to love British weather :roll:
Duke137
Post Wed Aug 15, 2012 12:55 pm
Dan = E30 technical support
Should have rang him first lol
e30-EVN
Post Wed Aug 15, 2012 12:57 pm
I don't like to pester people though Ferg. I have to bell him about something today anyways
