BTB3 Z3 Rack
reggid
Post Fri Aug 10, 2012 8:53 am
Anyone done it? I am trying and there isn't enough clearance with the knuckle and it rubs on the lower UJ clevis when cornering. I can grind the corner off but its only gonna give a few mm extra. The engine mounts are in good nick recently done.
What are some options?
Spacer under the engine mount,
crush the tube a bit
grind a few mm off clevis?
E30 325is with M20B31
sweep
Post Fri Aug 10, 2012 8:58 am
i have a btb3 and e46 clubsport rack
reggid
Post Sat Aug 11, 2012 2:15 am
i thought the e36/z3/e46 were essentially the same on the outside?
Post Sat Aug 11, 2012 9:31 am
Mikey_Boy
Post Sat Aug 11, 2012 9:41 am
reggid wrote:i thought the e36/z3/e46 were essentially the same on the outside?
I *think* the angles of the pinion are slightly different..
BTB3 and Z3 rack works - I had both on my M20 - no issues at all - well, apart from the ridiculous prices... :thumb:
reggid
Post Sat Aug 11, 2012 9:45 am
Righto will shim them in the mean time and get some higher shore mounts, the standard ones will shit themself in a short time anyway
reggid
Post Sat Aug 11, 2012 9:48 am
did you use standard engine mounts? how much clearance did you have?
