Loud whining from fan,325i sport
ETERNITY
Post Thu Aug 09, 2012 4:39 pm
A loud whining as the engine revs up and gets louder along with the speed.
The Car did get hot and the outside temp was 27
Any Ideas.
325i sport tech 2, lach silver, 1989, BBS RS 16 split rims,
[URL=http://s878.photobucket.com/user/ETERNI ... 0.jpg.html][img]http://i878.photobucket.com/albums/ab35 ... 46cc30.jpg[/img
ETERNITY
Post Mon Aug 13, 2012 3:12 pm
It makes the whining as its being revved
Rtaylor2208
Post Mon Aug 13, 2012 3:32 pm
Have you tested the viscous coupling when hot and cold. When the engine is cold you should be able to stop it easily with a rolled up newspaper, when at operating temp the paper should be shreaded.
If this tests ok the viscous is fine. I read in another post you had a inspection 2 service which I assume all the belts were replaced. It could be the belt is loose or even the fan has not been refitted tightly enough.
ETERNITY
Post Mon Aug 13, 2012 3:36 pm
No checked the belt and fan it's not loose,checked it
When car gets hot fan makes a loud whines
Post Mon Aug 13, 2012 3:50 pm
Sure it's the fan? Cam belt isn't far away, and a collapsed idler spindle will throw the belt against the front cover.
ETERNITY
Post Mon Aug 13, 2012 3:53 pm
Ok I will check while being revved stationary
SGP
Post Mon Aug 13, 2012 8:28 pm
The fan does make a loud turbine sound when it's engaged and revved. Make sure nothing around it is loose or touching it. The distributor cover for example.
If it ain't broke..
Fix it till it is :)
hongkongfuey
Mad-tango-geezer
Post Tue Aug 14, 2012 9:35 am
Check water pump?
with cars like mine,
