Battery drain Problem
raf
Post Thu Aug 09, 2012 3:16 pm
Im getting battery drain problems on my 1991 325i
I did a battery draw test using a voltmeter and its drawing 0.16 amps.
I found out its 2 fuses causing the problem, fuse 21 and fuse 27. If I remove fuse 27 the reading goes down to 0.14 on the voltmeter. and if I remove fuse number 21 the voltmeter reads 0.02 which is what its suppose to read.
My question is what should i be checking to find out what's causing the drain?[/b]
crossie
Post Thu Aug 09, 2012 4:43 pm
worth checking that the items under the fuses are going out?
crossie
Post Thu Aug 09, 2012 4:44 pm
27 door lock heater I hear is common short!
21 glove box light / torch may be worth checking!
