Got an e36 m3 rack 95, e30 tie rods, I bought a e36 boot turns out it's too big,
E30 ones don't look like
It either pic below,
http://i223.photobucket.com/albums/dd26 ... 1420e6.jpg
Anyone?
E36 rack what boots do I need?
Jozi
Check the part number from the rack on realoem/bmwfans and find the correct boot that way. A e36 M3 one should fit though. You can use the e36 tie-rods as well.
aivaras325
I used hole e36 (e36 325 94' coupe) steering rack in e30 ( e30 316 '90). All changes were the spacers to hold it in place and the part that connects it to steering wheel. It was m50 conversation so hoses were from e36. The e36 wasn't M one so not 100% that works for you.
rallycrossdriver
I am just doing this myself so would be interested to hear what you needed to do this job thanksaivaras325 wrote:I used hole e36 (e36 325 94' coupe) steering rack in e30 ( e30 316 '90). All changes were the spacers to hold it in place and the part that connects it to steering wheel. It was m50 conversation so hoses were from e36. The e36 wasn't M one so not 100% that works for you.
suedenim
At OP - Where abouts in London are you?
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
bmw9818
i just bought some universal boots, cut to size, theyll do the job!
in south in croydon/ streatham area,
rallycrossdriver
how did you connect the M3 rack to the E30 steering column did you buy bits made to measure or did you modifiy the bits youself?
