Fitting power steering....
bab-91
Post Mon Jul 30, 2012 3:25 pm
Currently without any power steering. Need help gathering the right bits and bobs.
So if anyone can help with a parts list. That would be great.
Pas Pump.... This do?
http://www.ebay.co.uk/itm/300748727430? ... 500wt_1287
e46 rack has to be a non m3 ending in 006?
steering reservoir
Custom UJ'S
Anything else?
maggspower
Turbo Farmer Tractor Driver
Post Mon Jul 30, 2012 3:42 pm
Hi there, I have all the bits you need barr the custom linkage, custom pipes (you can bend yours with some heat)and spacers to fit the rack(speak to DanThe for all these)
The rack you need is the clubsport end with an 067 part number, I have one. You will also need new track rod ends unless you use your current ones.
I'm assuming the engine is an m20? I'll do the kit that I have for £175 posted. That will be the rack, pump and mounts, pipes and resevoir, pullys and I'm sure I can find a belt too.
Chuck me a PM if you are interested.
Cheers Byron
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Jul 30, 2012 4:06 pm
Be aware that while the pumps are essentially the same, they all feature different mounts that are specific to the engine. While you can buy a pump with no mounts on eBay, you'll find it hard to find a bare mount, so make sure the pump you buy comes complete with the mount you need.
You might also need to check the front of your engine that you have the correct pulley; I seem to remember reading that some cars had only a twin-belt pulley (for alt/fan and aircon), when you need the three-belt pulley to drive the PAS pump. You can't use the aircon pulley for the PAS pump.
bab-91
Post Mon Jul 30, 2012 4:50 pm
Grrrmachine wrote:Be aware that while the pumps are essentially the same, they all feature different mounts that are specific to the engine. While you can buy a pump with no mounts on eBay, you'll find it hard to find a bare mount, so make sure the pump you buy comes complete with the mount you need.
Ah so not all m20 engines have the right pulley... I'll need to check knowing sods law it won't.
maggspower PM sent
Grrrmachine
Post Mon Jul 30, 2012 6:06 pm
Also, not all M20 engines share the same pump mount; I took the pump of my M20B20, and it wouldn't fit to the M20B25 I got from an E34...
