Flickering temp gauge *help*
ANDY325TOURING
Post Thu Jul 26, 2012 5:41 pm
is this a common problem with a known fix?
Cloggy Saint
Post Thu Jul 26, 2012 6:16 pm
Most likely cause is the nut on the back of the gauge has come loose. Remove the cluster, tighten it up and it should be ok.
ANDY325TOURING
Post Thu Jul 26, 2012 8:01 pm
Like it, its an unerving bugger.
steve_k
Post Thu Jul 26, 2012 8:17 pm
i could be wrong but it could also be a problem with the brown temp sensor (near the thermostat).
could be wrong though.
ANDY325TOURING
Post Sat Jul 28, 2012 10:21 pm
thats an easy 'try' before i remove clocks....
Worth a go.
ANDY325TOURING
Post Mon Aug 13, 2012 6:56 pm
brown temp sensor did the trick.
steve_k
Post Mon Aug 13, 2012 7:33 pm
ANDY325TOURING wrote:brown temp sensor did the trick.
:eek: wow I was right :mad:
d1mkaz
Post Mon Aug 13, 2012 8:09 pm
how was it flickering?
ANDY325TOURING
Post Tue Aug 14, 2012 11:51 am
Power on, temp rises, needle flickered back and fourth.....
clarko74
Post Tue Aug 14, 2012 12:24 pm
ANDY325TOURING wrote:Power on, temp rises, needle flickered back and fourth.....
Exactly the same as what happened to mine, that was the brown temp sensor too.
clarko74
