Immobiliser issue...
jmc330i
Post Sun Jul 22, 2012 8:25 pm
Got an immobiliser with one of these plugs (pic below) to deactivate it. But it doesn't always make a contact, which can be a right pain!
Anyone know if these are coded, or can I pull the socket out and join the wires together to effectively remove the immobiliser?
James
'91 325i Sport
'93 318i touring 16v
Post Sun Jul 22, 2012 9:36 pm
Should connect in at the socket with two green wires above the glovebox. Remove the immobiliser plug and link the two greens from the loom above with a plug fitted with a loop of wire.
jmc330i
Post Sun Jul 22, 2012 10:08 pm
Thanks Brian 8)
So would this be a dealer fit immobiliser, or some sort of aftermarket affair?
James
'91 325i Sport
