Oil dripping from the oil filter housing.
Striker
Post Fri Nov 18, 2005 6:30 pm
Hi all,
I've got oil dripping from the oil filter housing on a 325. It's not the mating between the housing and the block but right at the bottom of the housing below the oil cooler pipes.
Can this be repaired or does it need replacing?
Cheers, Andy
GDBN
Post Fri Nov 18, 2005 10:07 pm
It is probably coming from the oil control valve. I changed the gasket on mine last week - doesn't take long.
Here is a guide http://e30.bmwdiy.info/oil-leak/index.html to changing it.
The parts are sold as a kit which is just a new snap ring and cover with o ring attached.
Hope it helps ...
G
Post Fri Nov 18, 2005 10:36 pm
Exactly as GDBN says!
Never realised that the replacement O ring was an improved material though. I have always though it just hardened with heat and age.
Striker
Post Sat Nov 19, 2005 5:09 pm
Thanks,
I ordered the part today, Ԛ£5 something. Result
Cheers, Andy
